Old 02-10-2019, 12:23 PM   #10 (permalink)
Angel And The Wolf
This one is more aesthetically pleasing. two solidly mounted booms, one from each side of the front of the trike, support a canted swivel plate, whereon are mounted a reverse rake set of springer forks. As the trike handle bars are turned, a chain turns the swivel mounted springer forks to the side, supporting the outer front corner of the trike in a turn. The canted plate will displace the bottom of the front tire further out than the top, helping to keep cornering forces from trying to push the tire off it's bead.
Name:	Trike Trailing Rake.JPG
