Pretty much the only diesel that I know of that shares that bolt pattern is the old Olds 4.3 v6 from the early 80's, but those are pretty rare and aren't direct injection, so they aren't especially efficient. S10's came with 4 cylinder diesels from Isuzu I think but have no idea what bolt pattern those are.
Another important consideration is the trans in your car is electronically controlled by the pcm, so you will have to come up with a trans control for it. Aftermarket trans controllers do exist, but something to keep in mind.
My suggestion for best bang for the buck would be a vw alh, but it would take a good bit of fab work to make it happen. Someone has one in a fiero, so I know it can be made to work.
