Old 02-15-2019, 08:41 AM   #35 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Originally Posted by Shaneajanderson View Post
I heard recently about something like this, I believe it was Mazda that was experimenting with it. The efficiency was supposed to largely come from the fact that it can run on duel fuel. It's supposed to have a tank for diesel, and one for gas. Depending on engine speed, load, and temperature it's supposed to adjust the mix (and it runs on the diesel ignition cycle regardless). Supposedly It can also run on strictly one or the other, but it's optimum would be while running both.
It does not have a second tank, it just uses gasoline compression ignition instead of spark under some circumstances.
Gasoline engine through and through.
