I have a friend who does circuit races with the BYD F0, which is basically an Aygo clone featuring the variable valve motor.
Easy to get it to handle, but not much you can do that will make a dent in the performance difference to bigger-engined small cars like the Mirage. Though if you do get 100 hp out of the motor, that would be fantastic.
Before significant ride height or undertray modifications, you might want to look at creating an airdam for the same effect without compromising suspension stroke.
Doubt you can get 6s 0-100 with 100 hp. Maybe with around 130. Target weight of about 560 kg, given the frontal area, maybe you can get 7s. Depends on gearing and torque. But it will be fun to see how fast it can go.
