Old 02-19-2019, 11:58 AM   #30 (permalink)
ratgreen
I hope you've changed any o rings on the fuel pipes, if your engine has them that is. I'm not familiar with om603.
'98 OM606 E class Merc
Running on veg oil
35mpg average (tank to tank)
225 45 17 > 215 55 17 @ 55psi
LED lights all around inc headlights
Planned: electric turbo turbine generator (WIP), EGR coolant heat exchanger, Front air dam, solar panel, lithium battery pack, alt delete, full undertray, weight reduction, block insulation, engine bay insulation.
