Old 02-19-2019, 01:16 PM   #159 (permalink)
Ironside
Thanks for the reply and the link Stubby79, this static timing seems to be a compromise and I think the engine would be more efficient with variable timing. It probably won't matter much on a trail bike, but I might need to install a new engine in the Dreamliner. It's currently running a 125 Atc motor, and over here they are as rare as rocking horse manure.
I've got a rotor from a YX 140, which gives an extra 10 deg. of advance. If I use that with it's original CDI, theoretically, I should be able to vary the timing from about 17deg to a maximum of 37 degrees. Got to be better than static timing, if it doesn't work I can go back to the standard setup.
I cant ride the bike yet, I'm waiting for some cycle parts to arrive. In the meantime I'll check that everything fits and source a suitable CDI.
Pete.
