Old 02-19-2019, 03:08 PM   #161 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Just tested mine with a timing light...the timing mark barely moved as I revved it up. Disappointing, and a bit inconclusive. Might have gained like 5 degrees, between idle and probably 6 to 8k rpm.
On the other hand, I also had my tach light out, which I used to set the idle yesterday...hit 11,500 rpm quickly, before I chickened out. That's good...wasn't sure it would do much past the 8k limit the old CDI box.
Self-advancing timing would be nice...lack there of might explain the need for 1500rpm idle?
Edit: I take that back; after thinking about it, I think it appeared to be retarding slightly, which I attribute to the timing light having trouble keeping up. Meaning it is fixed.
The Following User Says Thank You to Stubby79 For This Useful Post:
Ironside (02-20-2019)
