Old 02-20-2019, 05:21 PM   #45 (permalink)
aerohead
wet the bed
Originally Posted by gumby79 View Post
I am to upgrade the transmission rated for 400 foot pounds of torque( Factory stock motor is rated 400) 472 to the tireson the 1-2 shift.with the 16cm housing on the H1C turbo pushing 17psi. Now I have a HX35W/ 12 hitting 20psi(stock fuel). That lasted about 2.5 weeks . The trans wet the bed. 2 days after the new to me turboI started hearong a planitary(i think) making a worbling noise very faint. Then ~100 mi fromthe house it started grawling. 45mi later it stoped .
Options
47re/h is rated for 45094-2002
48re 570 2003-2007
Both require sorcing a stock starter , tv cable,and adapror from the respective motor 96mph max
Allison
4 speed 545 drop in with spair parts from a 5.9 Cumins med. duity box van 65mph max
5speed 1000same + stand alone TCM. 80mph max.
Coments consurns?
Ouch!!!!!!!!!!!!!!! do you have a way to get around? It's a long walk to Sherman.Keep us apprised.
