Redpoint, yes sorry, I put it wrongly. However, it's not about moving heat from the engine, it's about cold/hot firing tip.
Arcosine care to elaborate?
what could go wrong with indexing a sparkplug? Or side gaoing it?
Alot of engines will run just as well with one grade hotter plug. Most engines are specified hotter anyway on generation shifts. Can see anything wrong wtith that as long as eco driving is the primary drive style.
Low Octane might be a little controversial. But most engines will do just fine as long as the engine isn't pushed.
Running low oil is a well known trick among dragracers. The oil woild need to be changed more frequently, but orher than that, there should be no issues running on minimum on the dips tick.
