Thread: A few tips
Old 02-23-2019, 09:40 PM   #17 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I didn't see the explanation here yet so I'll do what I can. The difference between a "hot" and "cold" spark plug is how far the plug reaches into the combustion chamber. Ideally you would always use a plug that puts the electrode at the center of the combustion chamber but that is not feasible or possible a lot of the time due to mechanical interference and (here is the hot/cold part) the further from the head the plug extends the more heat is retained which does and will contribute to knock/preignition/detonation.
High performance cars use colder plugs because they run higher compression, generate more heat (more power, duh?), thus need to use a plug that will dissipate heat into the head via the spark plug threads.
Unless you have modified your engine significantly, use the oem spec plug.
https://youtu.be/lS5XofKnros
The Following 2 Users Say Thank You to ksa8907 For This Useful Post:
freebeard (02-26-2019), redpoint5 (02-26-2019)
