Old 02-24-2019, 02:30 AM   #48 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Couldn't find any specifics on Larry's Ghia,but I found this:
RSR Aero-horsepower Calculator-RB Racing
It's at the end of the 'document.'
Plug in drag coefficient
Frontal area
Weight
Speed
and hit the button,for
required horsepower
and aero horsepower loss is also provided
I did it for Spirit and it gave me 128-mph,at a discounted 147.17 horsepower.
It's out ahead of nothing
I threw some numbers in for Gumby's Dodge:
Cd 0.45
36.9 sq-ft
4,000-lbs
130-mph
= 298.82-horsepower (close to my Mini Cooper-based estimate)
With same specs and 150-mph
= 453.64-horsepower
If 'Tonto' was slicked down to Spirit's 2012 drag coefficient he'd need only
281.4-horsepower for 150-mph.But they'd only let him do it for time,not a record.
recalculated your HP numbers to TQ
as follows:using https://spicerparts horsepower-torque-calculator
Spirit 147.17hp @5600=138TQ
on the H1C/16 17psi max 1/2 way through 2nsd gear
the whale uncorrected:
@143.8 HP @1976 =382.2 TQ on the rollers @6000 ft warm humid afternoon in Cedar City, UT
45 HP @2500 = 97TQ = 92.5mph @about 1/3 mi
wind tunnel with the oversize blockage skew said only 109HP =229TQ needed @ 87.14MPH
corrected to basic day:
178.3HP @1976=473.9TQ ](edit: PeakHP)
172.8HP @1846 =491.0TQ( edit : peek TQ)
proposed 130MPH 298.82HP @ 2000 = 784.7TQ Is this at a gas RPM say 5000?
If so, then 130MPH 298.82HP @ 5000 = 313.8TQ . 160.1TQ under stock@ 473.9TQ
proposed 150MPH
453.64HP @ 2000= 1191.3TQ
gas RPM 453.64HP @ 5000=476.5 less than stock 20.26TQ to spare.
slicked down 150MPH
281.4HP @2000 = 591.2TQ
Gas RPM 281.4HP @ 5000= 295.6TQ a little over half stock available.
put the truck on a carbon diet and maybe 4000 lbs is possible, it tips the scale at 5500 lbs so the new HX35W12 that spools at about 1300 instead 2000+ as the governor cuts the fuel back will really help counter the current weight problem. I think you agree it responds more like a gas motor now. so a dyno comparison is coming. but will be skewed by the new trans.
thank you again for the help finding the target range data .
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
aerohead (02-27-2019)
