Old 02-25-2019, 09:24 PM   #4 (permalink)
S Keith
Originally Posted by Vman455 View Post
If it fails, replacing just the bad cells is the most economical way to go. If you want all new cells, there's a guy on Priuschat selling new replacement cells for less than $1600 at newpriusbatteries.com. You just pull the battery, swap out all the cells and bus bars and put it back in.
I personally own one of these and have observed a 40% degradation in usable capacity since June, 2018. Additionally, they have horribly inconsistent internal resistance (IR) due to shoddy construction.
Under heavy throttle, my car surges. I can watch the current surge from peak to mid-level 1-2 times per second because the high IR block voltage drops like a rock, and the car adjusts.
They are Chinese junk.
Prior to this, I had a hammered reconditioned piece of junk in my car (multiple modules were barely 50% rated capacity). It actually performed a little better due to the consistent IR.
$350 more for genuine Toyota/Panasonic is an infinitely better value.
The Following 3 Users Say Thank You to S Keith For This Useful Post:
MetroMPG (03-05-2019), whaemmel (03-10-2019), Xist (03-04-2019)
