Old 02-26-2019, 06:09 AM   #45 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
If you rev match skip shifting causes no wear, in fact it saves wear on the gears/ syncros you're not using, particularly if you alternate which gears you skip (difficult in a 5 speed- easier in a 6).
Same goes for the clutch, shifting is probably responsible for around 1% of total clutch wear (assuming a good driver), but fewer correctly matched shifts equals less wear. Less wear on the clutch hydraulics, throw bearings, shift fork, shifter bushing and cables etc -any of which can also go bad in time.
Also, 2nd tends to be the first syncro to die as it generally lives the hardest life, so if you could skip it half the time, you could double your gearbox life.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
deluxx (02-26-2019)
