Current sensor question
MPaulHomes, The controller config states the range for "current-sensor-amps-per-volt" to be 0-480. I purchased the 600A current sensors (bigger is better?) so can I use 960 for this value? The config accepts the setting, but I want to be sure the imbedded software will also be happy with it.
