Drivetrain
I built a low end torque engine for it. It’s a 383 stroker short block with 5.7 rods, cast dished pistons, 214 duration roller cam. I also have a set of AFR heads, 1.5 roller rockers. The intake is an aluminum Air Gap duel plain single quad. 10.5 to 1 compression with a stock idle with plenty of vacuum for the brakes. The online simulator claims the output to be about 410hp and 450 torque. I bought a self adjusting EFI kit for this engine. Pictures will follow.
The transmission is a T56 6spd.
Upgraded to Posi locker10bolt rear axle.
