Old 02-27-2019, 12:13 AM   #3 (permalink)
ChopStix
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
Suspension
I purchased and installed a 3" drop kit for the truck. It’s mainly a set of tubular A-frames, and a kit for the rear end. I plan to also install an air bag/compressor setup on the rear for load leveling while towing. I will also have to deal with the front frame rails being bent from all the deer strikes. But I have a plan which might make this task easier once I get this far. I also can't install the new front sway bar until the front frame rails get straightened/paralleled.
Brakes
I purchased a set of cross drilled rotors, hoses, SS lines, and pads
Wheels
Right now I'm running the stock steel wheels. But I will most likely swap to something nicer.
Tires
Right now I'm running Firestone Winter Force tires. But I will most likely swap to Kumho LRR tires.
ID:	34529   Click image for larger version
ID:	34530   Click image for larger version
ID:	34531   Click image for larger version
ID:	34654   Click image for larger version
