Old 03-03-2019, 11:08 AM   #9 (permalink)
prr
Highlander - '06 Toyota Highlander Limited 4WD
Do you mean, be sure they are not underinflated, or do you mean to go above MFG recommendation? I have been doing the latter for a few years--I get them aired up every 2 months. I don't know what PSI winter tires normally can call for.
EDIT: OK I just looked, and saw that winter tires are not normally supposed to be 48 PSI.
So I guess the idea is that a slightly over-inflated tire will cover more ground with the same amount of gas, increasing the mileage?
Both my vehicles recommend 35 PSI cold. I have been doing the Sienna (the other car, in addition to the Highlander) at 40 cold, because I read that doing this will increase the tread life, and my Sienna chews through tires like there's no tomorrow. Would doing this also increase MPG?
Tire pressure up! Stay with what feels safe, of course. I run 48psi in my winter tires as much because I like the handling better.
