Chris,
JW read the forum and says it is a small world. He figures you are buying the "L" from Scott? If that is correct JW will also plans to be at Palo Alto tomorrow afternoon.
JW has figured out a way to use a different tire on the L (a size that is available and not so $$$) but it requires a suspension mod that he designed. The original shock spring set-up is pretty soft and the newer bigger tire rubs without stiffening the rear end.
I've seen the mod and it is a nice coil over with a mounting bracket. A definite improvement.
I'm pretty new to this foum so if i figure out how I'll send you JW's email address.
EVDRVR
