Old 03-04-2019, 08:28 PM   #32 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by squirrl22 View Post
Couple things you can do, that I did with my 1.6 Jetta diesel: 1. wrap a nicrome wire around each injector, attach to your battery via a relay keyed to your ignition. Ignition on, the wires almost instantly warm up to 200 F(depending on wire type, length, thickness) which then warms your incoming fuel.
2. modify your rev limiter, so that it doesn't start cutting off your fuel @3000rpm, and lets you get full fueling all the way to your rev limit before cutting off the fuel.
Both create a big improvement in driveability, and preheating the oil will save you a LOT of engine damage (coking of injectors& combustion chamber, lubricating oil turning int sludge, etc)
Interesting ideas, I will have a look and see if they would work (I know you can adjust the fuelling rack so that it doesn't lean out as much higher in the rev range)
Originally Posted by ratgreen View Post
I hope you've changed any o rings on the fuel pipes, if your engine has them that is. I'm not familiar with om603.
Not changed anything on the fuelling side yet - no leaks so leaving well alone ( apart from possible fuel filter changes
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
