Old 03-05-2019, 06:23 PM   #11 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by 2016 Versa View Post
That must come with getting older. When I was younger and working 40-70 hours a week if something needed to be done I'd do it as soon as possible, now I'm disabled and I put things off as long as possible. Lots of times I don't feel like doing whatever it is that needs doing because of chronic back pain but sometimes I'm just lazy and put it off. I've got 4 cars that need work as soon as the weather permits. One needs a tie rod end replaced but it's not to the point of not being safe so it can wait till spring, two need the timing belts replaced because of age, and the other is leaking brake fluid and isn't being driven at the time, I suspect it's probably got a a leaking wheel cylinder. I used to do a timing belt/water pump on an Escort in about 4 hours. With the back pain and having to stop and rest I think the last one I did took about 8 hours spread out over a few days. I can only stand to be bent over under the hood a few minutes at a time before my back is killing me.
Book time on the TDI is 8 hours by the time you pull out all of the turbo plumbing and put it back in. I travel enough that I don't want to waste a weekend doing car maintenance anymore.
