Old 03-07-2019, 06:56 PM   #8 (permalink)
S Keith
Originally Posted by vskid3 View Post
I'm not using EV mode to cruise around on the battery until it's dead, just as a kill switch. The warm up stages can keep the ICE running when it doesn't need to be if you don't get to S4. I use it to P&G and coast to stops when it would normally have the ICE running.
You are still subject to pro #1 and cons 1-6 with your described use and likely saving almost no gas.
