The model Y will be built in Gigafactory 1 by... robots?
https://www.teslarati.com/tesla-mode...ought-factory/
It did not work with the Model 3. You cannot experiment too much if you are desperate to raise the output at the same time.
But time has moved on and lessons have been learned. The Model Y offers a clean slate with less pressure.
This could be interesting.
