Old 03-08-2019, 12:09 PM   #4 (permalink)
Piotrsko
Since I have one also, 1st: you are a couple of inches taller than me, and it is body lift & taller tires. 2: the exhaust side will probably melt any nearby coroplast if the engine is doing any serious work. 3: I'm at 7886 # with my fat butt in the front seat and I go off road (gently since it is 2wd) all the time. I don't watch the bed or cab flex, it is way too scary. When you can see 2 inches of cab high camper shell in the side mirrors, the frame has to be flexing.
That said, I get anything from 18.5 to 22 mpg depending on fuel mix and how annoying commute traffic is. Back in the days of real diesel, I got 25. As I see it, aerodynamic drag is my biggest problem, under vehicle drag is probably 1/4 of total.
