Old 03-09-2019, 10:11 AM   #8 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Specifications
MODEL UP190
Engine Type Single-cylinder,4-Stroke,Air-cooled,OHV Gasoline Engine
Bore X Strorke/(mm) 90X66
Displacement Capacity/(cc) 420
Max.Output/(HP)/rpm 14/3600
Fuel Consumption/(g/kWh) ≤374
Less than is a start, though not a great one...
Brand Honda
Power Source Petrol
Power Details Air cooled 4-stroke OHV petrol engine, 25° inclined cylinder, horizontal shaft
Cylinder Sleeve Type Cast iron cylinder sleeve type
Bore x Stroke 82 x 64 mm
Compression 8.0 : 1
Max Power Output 8.1 Kw (11 HP) / 3600 rpm
Max Torque 23.5 Nm / 2.4 Kgm / 2500 rpm
Ignition System Transistorised
Starting Method Key Start
Fuel tank Capacity 6.5 litres
Specific Fuel Cons. 313 g/kW.hr
313 isn't so bad...but none of these compare to what's in your post.
