Originally Posted by Fat Charlie
You've got a 4.0 trying to shove power through an AW4 in order to move a literal brick through the air. There is so much inefficient slop in that chain, do you really think a tweak to fuel delivery is going to be noticeable in mpg once it gets through the engine, an anchormatic transmission, the driveline and tires and the aero losses? You'll notice more of an improvement by rearranging the deck chairs on the Titanic than upgrading an XJ's fuel filter.
If you got an improvement, it was because you had an injector that needed replacing. 1997 model year had OBDII. Get an SG or UG and you can see real numbers.
You sound a lot like those naysayers that say "if you want good mpg, buy a Prius". There's a guy on another forum that got 25 mpg in his Cherokee with an AW4 with a modest parts budget. It is possible to get good gas mileage in a 4.0
None of what you said was helpful. I'm interested in the potential effects contaminants can have on overall performance.
I'm also not upgrading the filter. I'm adding an additional filter. The OE micron rating is 10, and the performance one is 5 or 4.
