Old 03-10-2019, 01:28 PM   #61 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Arrow
SOLD!!
I have a 2000 Insight for sale, asking $2900 168k miles. It'll probably end up on EBay, but I'm posting it here first. I know the price is kinda high for this car's condition; there is a bit of flexibility. Clean title in my name in hand.
https://atlanta.craigslist.org/atl/c...837988434.html
I have more photos available and in higher quality than the attached ones here or the ones in the CL listing.
Most info is in the CL listing, but y'all know what Insights are so I'll post more detailed stuff here. There are like 24 photos on the CL ad but I can take more if requested.
- 12v battery is from 2017
- One of the ground straps was broken I replaced it with a new one from Honda
- This car had the driver's side wet seatbelt leak (common to G1 Insights) but I fixed it with silicone. I replaced the tabs holding the trim piece with new ones from Honda.
- Trunk latch did not work, I repaired the actuator with the 3d printed repair piece.
- IMA is on last legs, it should be bypassed, I'm just not sure of the legality of doing that and then selling the car. I just don't want to be held liable for something. I know how to do the bypass it isn't hard.
- One of the photos in the CL ad has a photo of the clutch switch I added, keeping it on most of the time will prolong the time before the IMA light turns on.
- I have grid charged the battery, and it's got a harness that's specific to my home-built grid charger. I made an adapter for it that works with the Prolong grid chargers if you have one of those, or if you were interested I could sell my grid charger.
- Passed emissions in February
- Enters lean burn easily
- No EGR-related herky-jerky problem in lean burn or under acceleration
- Transmission is QUIET
- Exterior looks really really good
Cons:
- Has RE92s but needs new tires pretty soon
- There's a photo in CL ad of where prev owner backed into something
- Has factory-installed audio system (it sucks)
- Probably due for TX fluid change
ID:	25628   Click image for larger version
The Following 2 Users Say Thank You to Natalya For This Useful Post:
Ecky (03-15-2019), fusion210 (03-10-2019)
