Ok Yeah ill need to get an ocsilliscope for that part for sure and I saw, Paul, that you have a resolver to encoder board. SWEET!!
Another thing came up that I am curious about. I can only seem to get the board to put out a signal if the pickit3 is hooked up and not with the USB terminal. Is the onboard USB just for programming as a "Program Mode" and need to be disconnected for "Run Mode"? I have got my motor to move when the PICKIT3 is hooked up only.
Thanks
