Originally Posted by Taylor95
Are you sure you want to make the 4wd unusable in your pickup while living in ND? Nothing is worse in the snow than a 2wd pickup. Except maybe a mustang.
Ok, to clarify this will only be a summer setup. I would be buying a pair of junkyard rims to put the same size tire as the rear on for winter. This rig's winter use is fully comprised of "It's deep enough that I NEED 4WD," but it doesn't get used much in the winter.
Fun fact: I work with a guy who owns only a mustang, and commutes 40 some miles every day, but almost never misses work.
