Old 03-14-2019, 10:56 AM   #9 (permalink)
Piotrsko
I noticed in your signature you have an "improved" turbo wheel. Data please, since I am not aware there is such an animal.
Afaik, there is the "wicked wheel" which is a copy of the pre bump nose 6.9 turbo, but that only affects turbo stall and does not increase boost over the 7.3 I have.
The best item I have seen is to get a 215 degree thermostat because they prefer to run hot which improves efficiency.
