The alcohol attacks anything in the fuel system sensitive to either alcohol or water.
Older cars leak before the valve seats die.
You bored the jets becuse it ran lean and jets didn't go to 90, you shaved the heads because it promoted higher compression and the 114 wouldn't ping.
