03-21-2019, 01:54 PM
#79 (permalink)
Originally Posted by Xist
This is way better than one of those evil assault rifles, right? Be sure to write down your answer. It is too late to change!
https://en.wikipedia.org/wiki/Mare's_Leg
Designed by Kenny "Von Dutch" Howard, an experienced artist and gunsmith,[5] the original Mare's Leg was made by cutting down a .44-40 caliber Winchester Model 1892 rifle to a size that could be worn in a large leg holster and used with one hand. The barrel was cut to a length of nine inches,[1] and much of the butt-stock was removed. ... The Bureau of Alcohol, Tobacco, and Firearms was not consulted before the program aired and producers had to pay taxes totaling $1,100 in connection with the National Firearms Act of 1934.
[snip]
A number of companies have marketed functional reproductions of the Mare's Leg, making them the same way as the original, by cutting down Winchester rifles. These reproductions also have the same legal restrictions as the original: a rifle may not have a barrel length less than 16 inches (41 cm) without obtaining a tax stamp from the ATF, in accordance with the National Firearms Act.[11]
Other companies have marketed reproductions originally made and sold as handguns.
Called a 'coach gun' because they're designed for use in tight quarters.
________________
.Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
