Diesels like heat- they tend to run best when you put in the highest temp thermostat you can find. Raising the temp on any IC engine raises the thermal efficiency- Gas or diesel. I got my best MPG on my 1986 Jetta diesel by using this coolant
https://www.evanscoolant.com/ and partially blocking the radiator.
