Old 03-22-2019, 07:36 PM   #40 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by squirrl22 View Post
Diesels like heat- they tend to run best when you put in the highest temp thermostat you can find. Raising the temp on any IC engine raises the thermal efficiency- Gas or diesel. I got my best MPG on my 1986 Jetta diesel by using this coolant https://www.evanscoolant.com/ and partially blocking the radiator.
Having replaced the stat, I'm happy with how it heats up now, and the roadtrip served to bleed the system through well.
At the moment I'll leave her be - I think the more pressing work will be getting the autobox fluid changed as I think it's a bigger issue at the moment
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
