Old 03-22-2019, 07:55 PM   #4 (permalink)
oil pan 4
The LS7 vett is kind of a gas hog.
I would think a normal 5.7L one could do close to 40 mpg if driven at around 55 to 60mph.
Upping the compression to 13 to 1 pretty much rules out lean burn.
Do the gear change.
I found a guy that replaced the 21lb stock wheels on a nissan leaf with used 10 pound wheels. These wheels new are about $620 each, he said they only gave him about a 2 to 3% increase in range. They do work but it's a huge expense for a pretty tiny gain.
If you could go with much narrower tires like a 225mm it might be worth it.
