It all depends on the air compressor.
The minimum you should run a few hundred feet is 10 gauge.
The max you can run in 1 inch conduit is three current carries in 4 gauge and a smaller ground. 4 gauge will limit you to around 70 amps at 100 feet.
Direct burial wire is UF-B.
