Originally Posted by gone-ot
...they're also touting their Regulated Voltage Control (RVC) system that is effectively an "on-demand only" field regulator system that holds battery voltage at ~ 12.3VDC instead of 14.7VDC all the time.
...instead, it only pumps the voltage up to 14.7VDC right after a heavy load (starting) then backs off to ~12.3VDC while cruising; but, goes back UP in alternator output voltage (if needed) during decelerations and breakings.
...good news for lamps and light bulbs, but not so good on batterys themselves.
After 8 years of owning a cruze with this system it has been so so on the bubs, it eats about 1-2 headlights per year but no other bulbs. Insofar as the battery, the OEM battery lasted 6 years. I too feared that the alternator would be hard on batteries but 6 years out of a battery these days isn't bad.
