Old 03-27-2019, 11:42 AM   #36 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Does measuring alternator output reliably tell you accessory draw? I used battery draw only since I know it's reliable and will only output what is being consumed. With an alternator, you don't know if it's feeding the battery, or supplying a load.
I suppose if you take a baseline measurement with the car running, you can subtract it from whatever the reading is when an accessory is turned on. Still unsure of accuracy since alternators can vary output depending on the load it senses and bump up voltages.
I've got a decent DC clamp meter that goes up to 400A that I use to measure starter draw.
EcoCivic (03-27-2019)
