If you offroad a lot, have them flip the axle so it's below the spring. Gives you 3" more ground clearance. The only advantage to dual axles is when you blow a tire at highway speeds you may still have something under the trailer holding it up while you pull over & stop. Tire drag would be the least important issue.
