Originally Posted by Daschicken
8K+ is a hell of a lot of weight for two tires. Even the 235/85/R16 trailer tires my workplace sells wouldn’t be enough to carry that weight at 110 PSI. Those things have sidewalls at least an inch thick too. Whatever you get, bring a temperature gun and make sure the tires aren’t getting above 180F. Preferably lower.
Yes and good thing I started adding worst case scenario weights. I doubt it would ever weigh 8k and I was thinking 9k axle, but didn't think tires..
Two axles will be installed..
