Old 04-10-2019, 12:08 AM   #8 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by 19bonestock88 View Post
In theory yes, but in practice, no.
In theory no, unless you hold constant velocity up and down the hill (i.e. acceleration = 0) and assume no increase in rolling resistance due to the trailer, which wouldn't be accurate. Even with the added mass of the trailer, the extra help you get from gravity is not enough to overcome the additional work required to move it in the first place. If you draw the FBD and do some algebra--
M = mass of car
m = mass of trailer
T = angle of hill (assuming same angle up and down)
d = distance of hill, and assuming duphill = ddownhill
FD = aerodynamic drag force, assumed same for both
FR,car < FR,car+trailer = force of rolling resistance
You end up with the following work required for each situation to go up and down a hill of distance d at inclination T:
Wcar = 2d(2Ma + 2FD + 2FR,car)
Wcar+trailer = 2d(2Ma + 2ma +2FD + 2FR,car+trailer)
The gravitational force does indeed cancel out, but it cancels out in both situations and you still have the force required to move the trailer around, whether uphill or downhill, which doesn't cancel. So, even if a = 0 it requires more work to get the car and trailer up and down the hill than the car alone, and thus more fuel.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
MetroMPG (05-16-2019)
