Old 04-10-2019, 06:27 PM   #66 (permalink)
woodstock74
TBD - '17 Toyota Corolla LE
Last 3: 36.26 mpg (US)
Starship - '08 Toyota Prius
90 day: 45.82 mpg (US)
Starship Resurrected - '08 Toyota Prius
The 'gurney' flap may just be a stiffener to prevent flutter in the panel.
Since the wheel well is in accelerated flow,it will be at a lower static pressure than at the forward stagnation point ahead of the radiator.That being,the air must scavenge out through any penetration in the wheel well,simply by virtue of the pressure differential.
Stiffener, perhaps. But what if the low-pressure draw of the wheel well and the spinning wheel wasn't deemed to be enough of a draw? Would they augment that draw?
The Following User Says Thank You to woodstock74 For This Useful Post:
aerohead (04-13-2019)
