[QUOTE=93Cobra#2771;595743]Biggest issue with skirting is underside access. There would need to be swingout panels to access dump connection, plus all gate valves (I have three, for example).
Other thing to think about is the bottom of most modern campers is already very smooth except for the axle assemblies themselves. They are sealed front to back with coreplast, and along a few drain assemblies stick down
Too high off of ground, which is the salient point. What needs fixing. Tank dumps and drain valves aren’t a hindrance.
