It's name would be Fortress of Solitude.
I just rent the ground, I'm not going to put a lot of work into it. But a single row of tires up against the asphalt as a retaining wall might raise the parking space above the flood plane. Seriously, the lane turns into a pond. Up level with the carport would be nice.
Maybe you don't have to cut off the bottom sidewalls.
