ok, thanks for the explanation.
Do the math for weight of the components, and compare with an engine driven propeller using a reduction gear to get the optimum tip speeds, and see what the added weight will cost. Then factor in generator losses.
I think your idea lends itself to low speed high lift aircraft, where the weight penalty gets absorbed better.
High speed regime, weight is king. Inline losses alone make it impractical.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
