Old 04-15-2019, 04:58 PM   #25 (permalink)
Shaneajanderson
Redneck Ecomodder
Originally Posted by skyking View Post
i'd worry less about hubcentric dimensions, more about pattern and offset, and try to get 14". the tire choices and prices tend to be much better; 13" is becoming a rarity. the studs can handle the centering loads and there are cheap plastic centering rings available also.
I did some looking online and it seems like 155/80/13 is still pretty easy to get a hold of, and a lot cheaper than 165/75/14, which is the closest equivalent. Besides, I'd rather not go too much wider than stock size which is 145.
I may end up ordering one set of the stock 12" while I can find them just to put off buying rims for another 60k miles or so.
