Old 04-16-2019, 01:19 PM   #33 (permalink)
EcoCivic
Originally Posted by ratgreen View Post
Thanks. I was under the impression Envirosafe R134A replacement was essentially r600a. Being both LPG based.
I'm from the UK so getting Envirosafe R134A replacement is expensive. R600a is easier to get.
https://www.es-refrigerants.com/docs/59264_645.pdf
That makes sense. Feel free to try it then. I think the worst thing that would happen is that you would need to remove the R600A and use fomething else if it doesn’t work well. And at least in the US, you can legally vent R600A into the atmosphere
