Old 04-16-2019, 04:38 PM   #34 (permalink)
jeff5may
Send a message via Yahoo to jeff5may
Refrigerant grade propane is r290. It has roughly the same pressure range as r22. Butane and isobutane both have lower pressures than r134a. If you are running a txv you'll have to run a blend.
The Following User Says Thank You to jeff5may For This Useful Post:
EcoCivic (04-16-2019)
