Old 04-16-2019, 07:25 PM   #33 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Okay, so 3/4ths the tire height minus the ground clearance, over 1/2 the tire height, I guess. Thanks.
It's easier to think of it as the simple ratio of body cover:wheel diameter, I think.
Except the text is talking about the wheel well radius, not the tire radius called out in the illustration. According to this a close fitting cycle fender would have more drag than a looser fitting one?
I don't think a cycle wheel in a fender is analogous. For one thing, it doesn't have a vehicle body around it. Second, as Hucho notes, in zero-yaw conditions the windstream at the front wheels is approaching at an angle of ~15 degrees, where no such shear would be present for the bike wheel.
The last few sentences of that paragraph I take to mean "...increased [wheel] radius and reduced [wheel housing] clearance," based on what's written before it.
We should also note that Hucho, citing an earlier study by Cogotti, indicates a completely linear relationship between wheel housing volume reduction and wheel drag. Interesting.
A tight-fitting Beemer-style lip would isolate the wheelwell more than an open 4x4 wheelwell — that's different than the cavity volume.
But that is directly related to the cavity volume, if we're holding other conditions constant, like the body cover.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
