Sean T -
Originally Posted by Sean T.
everyone on the taurus forum says that they breathe from underneath, so I'm guessing the air that goes under the air blocker should be enough... I know I'm going to need to keep an eye on the temp gauge though. If it gets high, I'm just going to remove it.
I think if the temps go up, you just have to start cutting holes in the cardboard. If your Taurus breathes under, then maybe that means trimming off the bottom (which helps those pesky clearance issues).
[ egg-salad => excellent,
CarloSW2
