Thread: Prius 75-91mpg
Old 04-22-2019, 11:06 AM   #23 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
You might be surprised to learn, but I did some math yesterday and it turns out the inertia of a wheel actually goes down as the aspect ratio (and thus overall diameter) goes up, because it spins more slowly. So, in effect, a 165/80r14 tire is "lighter", inertially speaking, than a 165/40r14.
You mean angular momentum? Rotational inertia is independent of speed.
All that as a prelude to saying, I don't get that result using representative tire dimensions and weights from Tire Rack--for the 185/55R14 and 185/75R14 I compared just now (they don't list any 165/xxR14), the larger tire still has higher angular momentum....
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Xist (04-24-2019)
